New BeoSound 1 will not play music with Multi-Room
I have a Moment, the BeoPlay A9, and now a BeoSound 1 (the new aluminum cone).  It was working fine, but now when I join a multi-room (usually started from the Moment playing from my DLNA server)  in the iOS app, the BeoSound 1 will join, but there is no music.  If I turn the volume dial, then the volume changes in the iOS app, and swiping will change songs, but no music.
The BeoSound 1 will stream directly from the DLNA server and works fine with airplay and bluetooth.
I have done the following:
reset the BeoSound 1
rebooted the Router
restarted the iphone
rebooted the Moment.
software is up to date.
Thoughts?
Hi
So the NL is one source
What happens if you tap again on the BS1 to change source ? Does it play something else ?
Yes. If I tap the top it will play another source. So the speaker works. It just has no sound in multi room, though it thinks it is joined (top light is on) and it controls the source and iOS app.  Odd as it was working then stopped. It is fine with Dlna stream, airplay from iPhone, and tunecast.
In the BeoSetup app on the BS1 is the multi room enabled switched on? Just incase it switched off by chance
