I don't know when this one was released, but I've just noticed a new SW version on B&O's BeoPort section that I've pasted below:If I read correctly, you can now hold the full BeoPort display/controls on your PC screen, meaning that with a dedicated PC, you get a better display and more navigation options than with a BeoSound 5..one more reason not to buy that BeoSound, don't you think?🤔
Version 5.02.01
This new version of BeoPlayer is designed for use with the BeoSound 5 / BeoMaster 5 or for BeoMedia 1 use.
New features included:
- It is now possible to hold the BeoPlayer control and dismiss hiding
- If you are using BeoMedia 1: You are not required to download this new release, but are encouraged to:
- if you experience problems using your current version, or
- if you have updated to a Windows version not supported by the current version
- The
Guide for the new release does not describe use with BeoMedia 1 and
therefore a separate Guide (available in English only) must be used.
