The problem is they simply don't go deep enough into the ear.
Yes I agree. Important to squeeze/roll the buds and quickly insert so they expand and achieve a good fit as per the instructions.- Most importantly, follow the manual on how to insert the comply tips and roll them, lift your ear open slightly and hold them in place for 10-15 seconds so the get a grip under the little bridge in your ear canal.
I feel stupid for asking this, but I need to. :/ Where exactly in the Beoplay app do I initiate firmware update for H5?
I've had these headphones for over 6 months now... I absolutely detest them. They are horrible in almost every way.
Got a pair of apple AirPods. They kill the H5's in every way, sounds, price, comfort.
If you are even considering these headphones try a pair of AirPods first.
Fully agree. Got rid of mine very quick, and happily using the AirPods.
The cable is way too rigid. -- Impossible to keep them in ear.
