New Beoplay H5, bluetooth
Michael wrote:
Depends very much on the material used. But I have noticed this on many different products as well. I wonder if those plastics can be a health hazard when they have deteriorated to the sticky mess.
One of my Beocom 2 table bases have got all sticky and messy....
@jonnyb
could you please, tell me how much sound they are leaking at a normal volume level?
Personally I don't like to sit next to someone, who wears headphones, when I clearly can hear what he is listening to :-(
I wouldn't want that to happen for someone else with me wearing the H5's.
They appear to be very good in that regard. At 60% volume they do not leak very much sound at all.
Thanks!
Has anyone got an idea of the sound compared to the H3:s? I love my H3:s, so if I can come close to that sound quality with out getting all tangled up in cables it would be a must have. Sadly my local dealer is closed for construction/updates of the store for the summer, so no chance for me to test them out, so any insight would be greatly appreciated.
Just got mine today, pink it is. 🙂
The package was very good, as always with B&O. Much as the same stuff as the H3.
Very fast recharge time with the magnet-usb charger. Just wish that they would have included a usb-wall socket charger.
The sound is surprisingly good. My old earset 3i doesn't come close. Very rich in detail yet surprisingly good in the bass. Best performance is around 50-70% of the volume. Very detailed for just playing lossy music.😁
They fit very well in the ear and around your neck.
//EA
I was surprised to get a notification in the Beoplay app telling me that a software update was already available.
I've installed it already. I think it has lessened the treble on the default audio profile.
To the owners of these earphones, I wanted to ask you a couple of questions before buying them myself:
- about the magnetic close: does it only turn them off, or when you separate them again they turn on? I had other earphones that did that and it drove me crazy because they would turn on by themselves everytime the magnets separated in my pocket.
- Can you also turn them off with the remote button? or only by pressing them together?
- Do they stick out of the ear a lot? It's hard to tell from the press pics.
Thanks!
Txenakis-
- once the h5 are pressed together, they're off and you need to press the start button again to turn them on. So they won't automatically turn on when incidentally put aside from each other.
- I think the only way of turning them on is to press the start button on the remote (the middle one).
- I have just practiced outside and they have remained in my ears quite nicely. I think once you have chosen the right earplug size, you're good to go. 😁
AND I've found the sound quite amazing for such little and light items like these. They sound very bass capable to me and very clear overall. Of course playing around with the Beoplay app's presets is fun, I might use them particularly for podcasts. After being back from a quick workout, I kept listening to them in my house haha !
P. S: they sounded a bit treble-ish at the shop but this has vanished completely since I'm back at home. Unless this is due to my house's modes (haha) I highly suspect some update- although I'm not sure I got notified at all.
KP6
Thank you for all the info.
