New: BeoPlay Connection Hub
Wow thanks 🤒 I really hope so
So that means I can adjust volume if I use it between my Sony TV and Beolab17?
Hi all, have just moved house and plan to put the S8 on my Panasonic tv. via the hub and optical
i also want to run my airport express into the hub for AirPlay, will the hub switch between the 2 sources and should I go aux from the airport to the Hub or use the power link cable that originally came with the S8. I had a version before the hub?
Hi blakspark,
Please connect the Airport Express to the 3.5mm input of the S8 Hub, the hub can then switch between the Airport Express and the TV as required.
Kind regards, Steve.
