New B&O TV BeoVison Harmony
Roger wrote:
No new info, just me thinking out loud 😁
Roger
That would be a happy day.
A positive
Steve at Sounds Heavenly wrote:
Hi MM,
That is an interesting thought!  Looking at the setup video, the C9 TV is programmed so that it will work from an external set-top box only, without using the TV tuner.  The Harmony then becomes the external set-top box from the LG TV's viewpoint.
The key to whether you could use BeoRemote One with just the C9 panel is to ask whether the Harmony (ie. B&O part) accepts the remote signals and passes them to the TV via HDMI, or if the TV has a bluetooth receiver that can access the BeoRemote One signals (to pass to the Harmony processor via HDMI).
Anyone know the answer please?
[EDIT]: Whilst typing my question, Michael has answered this!  The C9 panel won't function directly from a BeoRemote One, as the Harmony sound bar controls the pairing and gives instructions to the LG panel.
Kind regards, Steve.
Probably you and Michael are right - interesting though to investigate how this is done.....and if if opens up for further combinations of (LG-)tv’s and B&O sound/soundcenter/s.
@Steve - I did notice this ‘using the Harmony as an external set-top box’, but did not get how to understand this.
But why should that disable the tuners of the LG?
An ‘external set-top box’ can be many things - does not necessarily have something to do with tv tuner/s.
Would be odd to have to built-in tuners (today there are several different types of tuners) to the BeoSystem located in the stand.
The Eclipse uses the tuners of the LG-tv.
Hi MM,
Looking at B&O's setup video, when the installers go into the LG TV menu, they have to choose between "TV Tuner", "Set Top Box" and "TV Tuner + Set Top Box" - they chose "Set Top Box", which implies to me that the internal TV tuner is disabled.
So we have:
The LG TV is connected through HDMI and CAT to the Sound Centre, and needs a special WebOS-B&O App installed.
The Sound Centre controls the LG tv, the surround sound, the stand and provides the screen with metadata in 'Audio mode'.
Some questions remaining:
* Can audio settings be configured through the WebOS-B&O App? (Speaker Groups?)
* Will there be controls of the B&O Sources through the WebOS-B&O App?
* Can the internal tuner of the LG tv still be used? Or will every customer be forced to use STB's and the Sound Centre-connections?
* Will there be an on screen menu for Home Control (BLGW/BLI)?
Will my-buttons work?
poodleboy wrote:
Roger wrote:
Also, B&O is getting very close to becoming an audio supplier to LG - in much the same way as they were for the car industry, before they sold the name...
Roger
Is that new info?
B&O was with LG for audio for cellphone and TV in 2016, but that did not alot. It is now Meridian. Is there something happening newer than this?
link
This is a misunderstanding I have seen before on this Forum,
B&O have supplied sound/Branding to LG phones,
And LG have supplied TV to B&O
B&O have never had the same deal as MERIDIAN,
And IMO I hope that will never happen, that would be very bad for the B&O brand.
That B&O sell the Brand to Cellphone, Car audio and Laptop Audio, I understand as they do not sell those product them self (Any more)
Good questions, Emil!
Here is a link to an (the first I have seen) unboxing of the stock C9.
Millemissen wrote:
B&O would have had to engage in the whole tuner business again - unless the have been able to integrate ‘the C9-tuner option’ into the sound/stand-center.
No, today the tuner is pretty much a SOC, making it entirely a software exercise, Or you simply buy an OEM module at around 15 us$ in quantities.
Agree, Emil - but the Harmony is a stand and sound solution only compatible with the C9 panel from LG. Same goes for the new sound bar.
Roger
Roger
Oh, well - and when will we be introduced to that 😉
