New appartement, what would you do
I think to go for a BV7 + wall bracket.
I love the low floor stand but not easy to find in 2 hand...
Are you looking for the 7-6 or 7-4 speaker with it, or only screen?
7-6 speaker is wider than the actual screen.
I was thinking first to take it screen alone and just add the Beolab 4000.
But I don't know if it's a good idea...
shinobi52 wrote:
Hiort,
What's your opinion of BV7-55 vs the BV11-55 ?
I love the two models , I don't know wich one too choose.
I cannot compare since I have not owned any bv7. But I have a BV11-46 that I adore.
I think BV11 has a more modern panel than the BV7-55. Others may confirm that.
Bv11 support the BeoRemote One that I think is superior to the old remote. It has Netlink so that part is more up to date.
Also, I prefer the design to the BV7. It’s really nice on the motorized wall bracket if you want to swing it out from the wall.
Hi Hiort ( and the others),
Finally I have traded the Beoplay V1 for a BV7-55 mk2 + Beolab 7.2 ( this setup was more in my budget) and it's really a nice TV !
Do you know guys, if it's possible to setup the beolab 7 as Left+center+right and add beolabs for the rear ?
Thanks for your advice
I dont know for sure, but it would certainly makes sence if you could.
You can on the BV11 but that is another "sound engine" I believe.
The BL7-2 is a stereo speaker, a 2-channel speaker.
It can be used as L/R or as a (combined) center speaker with the BV7, when you add external front speakers.
As far as I remember you can’t set up rear speakers without having a center and the fronts.
The audio engine of the BV7 has much less possibilities for sound/speaker setup as what you may have been used to with the V1.
Hi Millemissen,
Thanks for your answer.
I must say that the Beolab 7.2 alone is quite impressive, i've played a DVD of James Brown live, and WOW, it was fantastic.
