You can see under settings which app that consumes battery.Same here! IPhone got properly hot these last few days.....
Same here!
Smart!
That confirms my suspicion. For the past 24 hours the B&O app consumed 72% of my battery !
Hi guys
Regarding the battery issue, we're on it. Getting quite hot in my pocket as well and sucks battery really fast. Will make a hotfix as soon as we have a solution.
Thomas, Bang & Olufsen
@badgersurf: DLNA is supported. Settings->Music->DLNA and add your server? Could you please send a feedback on the missing MK1 then we will look into it
After deleting the app and doing a factory reset on the moment and Essences I have managed to get the DLNA working on the Mk2 Essence, but the Mk1 now shows up the music from my beomaster 5 but will not add it to the queue and will not play anything. the only thing I can get to work is Tunin (forgot that the Mk1 does not support deezer). Any idea as how to get music to play from the Beomaster 5 via DLNA and the app on a MK1 essence?
Toby
Hi guys
Dear MrAndersen,
first thank you, for taking on a new aproach with the App. Are there any plans to integrate a shuffle button for DLNA-content / DLNA-playlists in the near future? I can access all DLNA-content, but a shuffle-option for my playlists would be a really great option. My playlists are usually sorted by genres (Blues, Jazz, Pop, Rock...) If I start the playlist „blues“ now, it becomes very boring after a while, because it always starts with the same sequence of songs.
Maybe have a look on the ios app 8player. There is a shuffle option integrated. Or you could ad a section in the setting to turn on/off shuffle in general.
BR
Beroli
The shuffle function shows up in the BLGW programming screen. Therefore, maybe it is possible? We also need the ALL JOIN feature.
I'm finding with the new app that often not all of my devices will show up in the multi-room tab. However, I can join devices manually by using the on-device physical control.
+ 1000 for shuffle
Let's avoid always-the same-order boring playlists, especially when a single playlist hosts all the songs (ca 4000)!
Thanks 😎
Another remark: Music from iTunes/Library/Songs displays only iTunes purchases and not AppleMusic downloads. Any chance to include downloads too?
+1000 for shuffle-play ... for me the most missing feature
Second would be the possibility to have volume-control on a BeoLink Converter!
