New app release hits beta
Guess B&O makes these changes only for their Apple app as I have not seen changes n Android yet where I am a Beta user. Or did I miss something Mr Anderson?
Still no dlna, so can't access on the BS essences (two mk2s) 95% my music which is on the server from the new app. I have the old beomusic app so I can access it, my wife does not have the old app so is stuck with out access if I am out of the house. She is saying why did we spend all this money when we could have got sonos and it would have worked!
Also with the new app have lost control of the mk1 essence in the office so again completely useless for my wife.
So all in  all wife is not happy, which means any thought of a new B&O TV or any other products is now out of the window, would be ok if this is a one off but the software while improving, lacks in the basics to make it truly usable
@Norwin: No you are correct. This change was so big that we could not do both platforms at the same time. I can however gladly say that we started on Android yesterday!
@badgersurf: DLNA is supported. Settings->Music->DLNA and add your server? Could you please send a feedback on the missing MK1 then we will look into it
Sandyb wrote:
Hmm that's strange..seems to work for me
I have my Moment connected to my BS4 12/65
See both screenshots below
Yes, I can create a group using the Moment like you do. But if I play on eg BS1, are in the Multiroom view, I do not see Moment, only BV11. ( see screenshots in earlier posts)
Yeah I'm with you now
Same for me
I'll report it in the feedback section
What happen in this view when controlling the volume level if you have several M5 or Moment will they got different logos or name?(I am in act to increase my system) Good if I also could lock the different volume levels and then increase or decrease the whole group at the same time.
Yeah, a master volyme would be good.
You know you can change the name of your Moment, if you do not want all those numbers? Can be done in the Moment settings.
Do you plan  to authorize any DLNA renderer to be used with your app ?
(today you can only add DLNA server as music source)
After the last update it seems like my phone is using a lot of battery power when the app is open. Not necessarily active, but just running in the background with no products in use. Today it went from 100% to 40% in a couple of hours getting pretty hot - even when just laying around.
i can't remember that I have updated or changed anything else recently and the problem seems to disappear when closing the app.
Anyone else noticed this? -just wanted to check to see if this is B&O app related or I have to look elsewhere.
Same here!
IPhone got properly hot these last few days.....
