New app release hits beta
I can't seem to pause (||) TuneIn (not logged) via the interface, I have to select StandBy ...
And I just had a period of hypersensitivity on the screen/app where a tap was treated as a double tap
I.e. The App would start and immediately stop playing the station
Strange... works for me (Beosound 1)
It would be useful if the volume buttons on the side of iOS devices can control volume of the bo devices
Vince
The buttons are doing the job, at least on the devices i own.
MrAndersen wrote:
If you are a beta tester please use the feedback in the app for bug reports. If you are not a beta tester, please drop me a message in here and I will add you. Looking forward to your comments.
I'd would  like to join the group of beta testers.
Dear Mr Andersson
I would be happy to be on your list of beta testers
M
Munin wrote:
Dear Mr Andersson
M
@Munin and @L1N0 send him a personal message - that way he has an email record that can be managed outside of beoworld
I experience the same thing. Buttons not working and the lock screen not showing volume or what's playing.
This happens on BP A6. Hopeit's something that will be fixed soon?
Just to be sure: did you set the lock screen command in Settings/Music/Commands?
Ahh that helped :o)
But it doesn't makes sense to hide this under "Music", since it also affects radio. Should be a general setting in my opinion. People who only uses the TuneIN part will never think of looking in the Music tap
