New A6 SW 1.12.....
ThatGuyFromDenmark wrote:
Seems like this hasn't been rolled out in Denmark yet, we're apparently the last to get updates as neither my A9 nor BeoVision Horizon can find any updates.
Why must you taunt me, B&O??? Why not make it available everywhere at once?
Im from Denmark :)
/Jacob
When are they going to fix the Bluetooth issue - i've had the essence Mk2 since it was launched and it's still not usable as it should be! Does anyone have a solution that doesn't involve the IR?
Im from Denmark :)
/Jacob
Me 2, and I've got the update
//Vejrup
It's got to be a personal vendetta against me then :(
Well, since this sw update fixes issues with... sw update.... it might be that your products suffer this issue, could be something with the network/router combination ?
Maybe a reset(wireless/wired change) of the A9 could get it to find the update ?
/Jacob
I tried that, no result. And it's able to play Spotify just fine, so I assume the network is working. The last update downloaded fine (1.11) and no change since that. I'll reach out to Beocare on Monday.
Found the problem - the date was off. Once I corrected the date on the A9, it found the software immediately. Didn't fix the problem on the Horizon though
