Just received a new-to-me BV11 and am trying to find NetRadio. There is a Radio, but not NetRadio. Is it possible there is none?
Also, I am unable to check for software updates or download PUC codes from the internet. In the advanced Service Menu there is no entry under "B&O NETWORK DOMAIN" so could this be the problem? I can't compare to my other BV11 because, as in my other post, I have to fix the mains suppression capacitors.
Thanks!
Gene
