Netlink: link to other products
Today I did some work on my NL and noticed that the secondary linked products do work again! I linked Beosystem 7000 and Beosound 3000 to one Beosound Shape. The cd3000, bg6000 (a.aux of the 3000), cd7000, ph7000 & tp7000 are sources off the Shape.
It also works for my original Core. Thought they had stopped updating this.
Same on my 1st gen Beosound 1.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
i noticed this too after the last update. I'm very happy it's working again :D
Assuming you have the BS Core with the Shape, I do not quite know what you mean. The sources from my linked (ML -> NL) BM/CD 6500 have been there all the time - I haven’t noticed any changes. This - as an example - is with one of my M3’s:
What is bothering me, is that they still haven’t made it possible to link a ML source to the products on the Mozart platform (in my case the  BS Theatre)
It was the "connect to secondary product" feature that has been broken for quite some time - when b&o radio was introduced to these devices. The drop down option was there, but the sources wouldn't be available.
I noticed that Tidal isn't available in the local sources list on my A9 and is thus missing as a source via the Halo. I can start tidal from the app, and the halo then shows Tidal as playing. Another consequence of this bug is that tidal's not available on my V1 where the core is integrated to it.
The BLGW and beoliving app see Tidal as a source on these devices so it must be an issue with the local sources list settings screen.
I've raised it as an issue with B&O.
carolpa wrote: Today I did some work on my NL and noticed that the secondary linked products do work again! I linked Beosystem 7000 and Beosound 3000 to one Beosound Shape. The cd3000, bg6000 (a.aux of the 3000), cd7000, ph7000 & tp7000 are sources off the Shape. Assuming you have the BS Core with the Shape, I do not quite know what you mean. The sources from my linked (ML -> NL) BM/CD 6500 have been there all the time - I haven’t noticed any changes. This - as an example - is with one of my M3’s: What is bothering me, is that they still haven’t made it possible to link a ML source to the products on the Mozart platform (in my case the  BS Theatre) The ‘Join workaround’ of course is possible there. But it would be nicer, if one could choose e.g. the CD6500 directly from the Beoremote - especially since the Theatre setup is my main room for listening to CD’s. MM
the BS3000 and BS7000 BLC both connected to the same Shape (Beosound Core) as primary and secundary beolink.
