Needs help to connect Beosound Ouverture & Beolab 3500.
 "press MENU then MENU then 0 then 2 then PLAY, then use the up arrow to switch, then store"
with my beo4?
Bellissimo! Now I have a beautiful aluminum tube but...with a great WOW EFFECT B&O STYLE!
...decided to use it as a desk clock!
Doesn`t work?
Stefan
Unfortunately does not work.
This is my new clock: beolab 3500!
Anyway, thanks for all the advice.
Giovanni
Just needs and upgrade by B&O. Can't remember the cost but not crazy money and at least you will have a working speaker!!!!
Jonnie
Can`t believe that you are giving up!
Took some hours to figure out what the issue is. Now we have it (I think!) and we nearly solve it.....
Did you really switch your Beolab to ML?
Press MENU - MENU -(twice) - 0 - 2 - GO (service menu, should be MCL or something like that displayed) - arrow up (to change to ML -
display shows ML..?) and GO (or STORE) again.
SW update here in Euroland is about 40-50 Euros for the eprom and maybe half an hour work.
Good luck.
Stefan
