Need assistance: Beo Terminal 7000
I'm looking for the BEO Terminal but I'm not sure if the 7000 version supports BEOMASTER 6000 or not. Can someone help me with this.
Beolink 7000 does not operate Beomaster 6000.
You will need the Terminal 6000.
https://www.beoworld.org/prod_details.asp?pid=994
Or the Terminal 8000, of course. But no stepped volume drops or reset! But it does work fine.
Jacques
Jacques
Beolink 7000 does not operate Beomaster 6000. You will need the Terminal 6000. https://www.beoworld.org/prod_details.asp?pid=994 Martin
Thank you, I think I will look for the Terminal 6000 for synchronization :)
Hi, Or the Terminal 8000, of course. But no stepped volume drops or reset! But it does work fine. Jacques
Thank you, I have a slightly off-topic question. My device operates on 120V power, is there any way to switch it to 220V by changing the power transformer?
Of course, if you can find one.
Jacques
