The tabled SACD data is questionable!
Firstly there is no question about the potential clipping of the CD data shown in the table and in the waveform display, however the SACD data was redigitised from an SACD player analogue out at a max. level 0f -3dBFS - any potentially clipped sample information has been lost in the re-sampling process! It was then normalised (amplified) to give a max. single amplitude of 0dBFS.
I don't think the two data sets are able to be compared becuase the SACD data is not what was on disc!
I do think the conclusions are correct however, because of the visual difference of the waveform displays, i.e. the CD waveform clearly has had more gain/compression applied to it than the SACD waveform.
And Atkinson's tentative suggestion, that this was done to make the SACD sound better than the CD, is also "interesting".
CCS - Brother.
link
Not too many folk think of brass when they imagine dynamic. This fair bounces and rumbles along.Its quite a test for any set of speakers,for the range of sound and ability to discriminate properly.
This is also what you can do with brass,
link
link
linklink
This next one has quite a range of sounds - Dance on vaseline - David Byrne & Thievery Corporation
link
Cast your fate to the wind - Sounds Orchestral version
linklink
When a blind man cries - Deep Purple, I think rather predicts the Pink Floyd sound, and not many folk realise it,
link
It's Oh SO Quiet
Bjรถrk
As Casdave has mentioned brass, I must insist that you try almost anything on "In the Digital Mood" released by GRP 25 years ago as the 'definitive digital performance' of Glenn Miller's music.  Forced to choose one track as 'dynamic' I'll take "American Patrol".
I hesitate to mention 2 other favorites in this category, but I will brave the flames.  :-)
Frankie Goes to Hollywood's "Welcome to the Pleasuredome", and force yourself to let it play untill 2:34 into the track.  BeoLab 5's are suggested.
Don Dorsey, "Bachbusters", track 15 the Toccota and Fugue.
Russ
casdave wrote:
excellent ! thank you :-)
casdave wrote:
Also good ! Always like Thievery  ๐Ÿ˜‚
casdave wrote:
There were several other "Sounds Orchestral" versions of this, in fact this one had the lowest listening count ... why did you pick this particular capture ?
nmartin771 wrote:
First I will go with one hit, big hit....
The Cult - She Sells Sanctuary
A favourite of mine too.
I'll add Song 2 - Blur
agree ๐Ÿ˜
The reason I picked out that particular version is that it has the highest resolution, and I prefer this version to the original one by Vince Guaraldi.
I'll add another one or two here,
link
link
Weird Fishes/Arpeggi - Radiohead
๐Ÿ™‚
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
