My Mk2 7-40 has a unique feature
Hi Forum,
I have just bought a Beovision 7-40 MK2, its pre HDMI of course, but there is a hdmi cable that goes in to the back of the TV. the unit has had a STB-T upgrade..
Could someone shed some light? ive search all over google but no luck!
See attached image
looks like it has a HD free view module fitted
Is the built-in DVI connection still free and useable?
Good morning.
If you look it looks like you have a DVI to HDMI convertor at the bottom of your TV in the picture.
Hi, You have the DVB-HD module installed, check your AP software readout if its over 30.00 then its the DVB HD module
Thanks guys, Its the DVB-HD upgrade, i plugged it in the DVI adapter and the picture improved greatly.
i wasn't too sure before as the cable wasn't long enough, but after a quick tug, i managed to get it in.
