My first ML/NL product
I am using both Beomaster and Beosound 5.
Dealer (summit NJ) has two sources running to one set of speakers and plans to do the same at my place. I will forget exactly how they will set this up. We had to do this so I could have music playing concurrently across my Beolabs and not incurious NL delay when using the Beovision 11. They are installing in early Feb. I will be there and let you guys know what components they used for the connectivity.
@Normann WMA Losless and MP3 up to 320 - as you see no FLAC No - thumbs down
@Simbohm probably they are using a PowerLink-switch from Bosscom or Almando
I can't imagine any other solution - would be nice if you tell us about it after the installation..
The switch-solution is something that I (without any financial interests) have promoted ever since the BV11 came out.
Note: the Media(audio)functions of the BV11 can not be used in other rooms unless you involve the NL/ML-converter. (with one exeption coming in spring: you have a V1 or another BV11 directly connected via NL).
Greetings Millemissen
Then it will be no cdrip for me.. Better to do this on the computer and then transfer it over to the BM5.
