Hi. Just a quick question, i own today a Encore and stream my music from the NAS.. When it comes to fileformat on the music, most of my music is playable on the Encore. So if i move my libary over to the beosound/beomaster this will work won't it?
My first ML/NL product
Pretty much the same.
You wrote about future-ripping to losles - and I told you to use FLAC (or WMA-losless).
If you rip with iTunes (as a Mac-user often do) to ALAC, you would have to convert afterwards.
Greetings Millemissen
Hi Normann,
Please do not forget to return - to tell us which decision you wil make 😮
Oksy. Thank you.. As of today nothing is linked together, so i have to do the hole ML job around the house also..
i am starting to feel the Bs5/Bm is the right product for me to start with.. And link everything from this and the future beovision..
Will you be able to use MOTS with this setup (no Beosound 5)?After an incredibly long debate with B&O, I have gone with the Beomaster 5, Masterlink gateway (connection to Lutron), some new speakers 12-2's with an 11 - there is also a playmaker in the mix Soni can stream music.
Hi Simbohm,
what you describe, seems a quite messy setup. i hope your B&O-dealer knows what he is doing.
Do you have the BM5 without the Beosound5?
If without, how is the BM5 connected to the BV11?
Normally I would say that it is impossible to run one set of speakers from 2 different masters at the same time - at least without a swich of some kind. Could you tell more about how it is connected???
When you rip to any losless format, you can always create (burn) a CD-A afterwards without any losses.
You want to rerip your cd-collection? If you have the BS5 as well, I would recommend to buy the ripdrive - it makes things much easier.
You can connect a V1 to the line-in of a A9. You need a special cable: RJ45-PowerLink to RCA. You can get that from your dealer - he should know that!
Hi.
What formats is it possible to rip the cd collection in with the ripdrive?
