My Current Setup - Now 7.1
I like !
You need some cable sock though. It will do wonders !
You have a BC2 and BS9000 !!
How are the beolab 9's with the lab 5s ?? which did you have first? or did you get them all together.
We are considering some speakers for the back.... with Lab5's currently in the front.
Not to woried about the cable sock at this stage as we are rebuilding before the year is out.
I previously had the BL5's front, BL7.2 Centre and BL3's Rear. I have just added the BL9's as middle for the 7.1 surround. The sound was amazing before, now is it mind blowing when playing Bluray uncompressed.
What the pictures do not show is the screen that drops down infront of the plasma and a HD projector.
Nice setup.  Love the Pioneer plasma, and of course, all of your B&O stuff.  Would be great to see it again when you're all done (if you're rebuilding).
I would love to hear that setup, the speakers you have in that config would be awesome to watch and hear blu ray.  Which blu ray player are you using?
Hey, have you seen  http://www.cnet.com.au/top-20-must-have-blu-ray-discs-339295891.htm
Cheers
Michael.
A beocenter 2, a Beosound 9000 and a Beosound 5??? Are you having some trouble to listen to the source you want? I didn't know it was possible to add so many sources in a one room setup!😕
The Beosound5 was only in one picture... so I assumed he was testing it maybe?
Well spotted Luke 😕
That's maybe easier to set up with (only) the BC2 and the BS9000.
The Beosound 5 is in another room. Yes well spotted!
It seems i have a slight passion for certain B&O products.
Hello
i have a question i see that you dont have a b&o tv in the second picture so is
it possible to use a diffrent kind of tv whit b&o speakers and if yes what do you need to do that
thanks
I use the Beosystem 3 to connect all my periferals. PS3, HD set top box/pvr, Apple TV and Bluray player.
I also use this for both the plasma and a HD Projector in the same room.
