Davidson wrote:
So even with SW update, it won't help? Will B&O have a "fix" for this?
No, it's not a SW issue. We've discussed this many times in the past. Lots of people on here go on about how great the Beosystem 3 is at producing a great picture - it is - but it has its flaws. One of these is an inability to decode True HD, which is now the default audio format on a Blu-ray movie. I've argued in the past that this makes Blu-ray playback on an expensive Beosystem 3 TV (BV7-55 and BV12 are two good examples) as a bit pointless as half the reason for buying a Blu-ray is the uncompressed audio track.
People on here complain about negativity, but i'd be non-plussed and a bit disappointed if I bought a £15,000 B&O "top of the range" TV and found it couldn't even decode the default audio format on a Blu-ray disc. And, as I said above, it's not a recent issue. We discussed this about a year ago. You would have thought B&O would have upgraded the BS3 to support this format between now and then.
Without the uncompressed audio, you might as well rent or buy a 1080p movie from iTunes or similar. Why? You get a Blu-ray competing picture, but fairly similar audio. No point wasting your money on Blu-rays when you can't decode the audio track and are left with Dolby Digital. I stopped buying Blu-rays for that reason. They can cost £17 a disc, even discounted from Amazon.
Anyway, no, it can't be fixed. Decoding True HD isn't software-based. It needs support in the hardware.
