My BV 7-40 MKIII Full HD Dark Grey has finally arrived! Pictures, info, and much more...!
I'd like to see all the connections... maybe a photo of the manuel page where the connections are decribed... on the BV7-32, the schema is on the back of the panel that hides the connections...
 p.
There is a problem with the links, all photos with "bilder-a" do not show up, there is a login screen instead...
p.
wtlc2zpx:
p.
Hm..? Try again! It works fine from my computer? Anyone else ho have trouble with the picture-links?
 R. Fredrik L.
Yepp me too
Beolab:
All pix with "bilder-a" in the link.
p.
Then i now the problem! Thanks! For me it´s work fine strangely?
Edit: Now the problem is solved!
I have a black BV-7 32 and a freind has the light silver version...and we both agree that the black looks much better...it looks more expensive in the flesh and when you watch something on the screen the frame and speaker beneath disappear from your view...whereas when you watch his screen you always see the bright silver frame and speaker below.
<><><>Hi Fredrik,
is the color of the display red (dot matrix) or white? And could you post a pic?
And is the cinema control module standard or optional like BV7 MK II ?
Thanks Stefan<>
