My B&O Home
I wanted to say that this option will be even more expensive than the new one, but I did prefer to wait for your confirmation.
It is likely that your service prices are more expensive than with us.  I think builders and other contractors.
But it's an interesting way of build.
It's smart to do a installation yourself.
So, at least you'll have everything under control.
marexy wrote:
It's smart to do a installation yourself. So, at least you'll have everything under control.
I have everything under control when I have a beer or 2... πŸ»πŸ’―πŸ€£
UPDATE
I changed the build again...
I’m adding audio in-wall keypads...
I want dedicated audio control in every room and an iPhone and Alexa is not good enough...
RTI do the best looking audio wall keypads in my opinion...
Does anyone of any other brands that look good?...
Kiran wrote:
UPDATE
I’m adding dedicated audio in wall keypads...
I want audio control in every room and an iPhone and Alexa is not enough...
That is a wise decision!
Always thought the Busch
benjnz wrote:
Always thought the Busch priOn was a nice panel...
I had a look at these... they are nice!
Ideally, I want a panel to fit in a square back box...
I want hard keys to control the music with or without an LCD...
And I really don’t want a panel where the keys are programmable to what you want them to be... they should be specific for music...
Bedroom 1 progress...
All wiring complete!
What are the long steele tubes going through the floor for ?
They are plastic and they are for the 2 extractors in the kitchen downstairs... πŸ‘πŸ»
Have you settled on AV distribution as yet Kiran?
I'm looking to replace a UHD Atlona solution for something HDR happy, looking at the Opus and Omni, curious as to your direction...
