My B&O Home
Impressive job Kiran!
Hi Kiran,
Hope you had a structural engineer / building control check out the roof design before cutting those roof rafter A frames!
Graham
Wow
It’s only a power cable...
I’m not saying I’m the expert but I do keep a track of all wiring...
Yes we haven’t used any conduit to rerun any cables and I don’t know how that helps with hazards, but we have taken all measures into account to keep it safe...
I’m sure my electricians know what they are doing...
With regards to the second floor dormer, I’m sure the builders know what they are doing too... ☺️☺️
Progress...
Virgin is up and running in the server room...
I can’t wait for the AC and door to arrive....
I don’t want to start terminating any connections or build the rack any further with all the dust flying around...
And yes the Netgear Nighthawk X6 has been put through its paces. It’s lost 2 of its 6 antennas somewhere in the build lol...
I don’t take what builders say for granted. They don’t always follow the planner... I look at the materials being used and how well the job is done...
40 of these bolts used up here...
Those bolts should be enough, how big is the m2 of the roof? Just wandering for snowload. But eyeballing it it looks enough😁
I think that a civil or structural engineer might have a different viewpoint. Building Control would probably want to see calculations.
Graham
What a buzzkill...
Can we get back to the electronics side of things...
Progress...
The first Ubiquiti wireless access point is in!
The range is good but I need more...
Server room is a mess...
I love this WAP... very good range and very easy to configure...
Mad speeds!!!
