My B&O Home
Just an example for KNX products....
http://www.basalte.be/en/products/switches
Stefan
KNX looks nice but I guarantee you my Lutron setup will be second to none.
Brushed aluminium wall plates finished with black buttons and custom engraving and the same for the Grafik Eye QSs. The same for RF tabletop keypads. I will also have Pico switches for the cars to operate the gates and set the scene before you come inside.
I have no components installed yet. I don't have anything to show. All wiring is happening as we speak. Components and lighting panel should arrive in a week or two.
bigdeniz wrote:
Hi Kiran,
I'm also following your building project with many interest.
Can you post some images from your Lutron install? I'm thinking about a Lutron install to control my B&O equipment. In germany with have the KNX equipment from Gira or Busch & Jaeger for example. But the Lutron Palladiom looks much better i think.
Hi Bigdeniz
The Lutron Palladiom series looks wicked! Especially the thermostat. I really wanted to use the whole series but I can't in my install so I went for the International SeeTouch Keypads and 2 Grafik Eye QS.
I will use some full spec 15 button keypads programmed to do many things. 👍🏻👍🏻
Why you can't install the Palladiom?
Because in some parts of the house I have electric underfloor heating and in other parts I have water underfloor heating.
The Palladiom thermostat does not support something in my setup.
ok, i understand. Here in germany the Lutron series are much more expensive than the KNX equipment. You can only buy the equipment at one Lutron partner. How is it in your case?
Yes the Lutron is more expensive than KNX here too.
There are a few certified dealers I know that are close to me but I'm working with my original Control4 home automation guy to get this installed and certified so I can get the 8 year warranty.
He was originally going to install Control4 and Philips Dynalight for me but it has all changed lol.
Progress...
