My B&O Home
fedenunez wrote:
Did you try with the BeoLink App 1?
Can you share your BLGW configuration?
I just realised you may be right about the sources in the interface tab in the blgw. I will check that when I get home.
All I did was added the NL/ML to the zone. I just realised I captured all the sources for the other equipment when I initially set it up a few days ago.
Thanks for the heads up 👍🏻💯
I will update you shortly.
Hi Fedenunez
Thanks for your help.
Because I am using the speakers for the BLC through the NL Avant in an integrated setup, the sources have been hidden to choose in the blgw. They can only be chosen from the TV. See picture below.
I had to scroll down and "unhide" the sources in the TV's interface.
I now have full control. 🍕
You are welcome!
Progress...
There are too many pillars. We're getting rid of some...
I prefer the Beolink2 app. It's very well done 👍🏻
It would be nice to see both icons of the Avant and BS9000 though like the BeoMusic app.
Beolink2:
BeoMusic:
The BLC icon shows up when the Avant is standby 👍🏻
Kitchen should be the Beosound 2 icon but that's not working in the app so far.
Hi All
I currently have 2 Nest thermostats. Upstairs and downstairs.
I have integrated this in the blgw temporarily until the Heatmiser Neohub gets installed.
I can only assign the Nest thermostat to one zone so I have made extra zones downstairs and upstairs.
Is it possible to assign the downstairs thermostat to all downstairs zones? And the same for upstairs?
Can anyone please advise. Thank you.
Progress...
Progress...
Pillars have come down.
Steel beams in place.
Kiran wrote:
Progress...
Regards
Kiran
Born in NL; I ride ML
That looks better without the pillars. Coming in nicely Kiran.
