My B&O Home
UPDATE
The Beolink Gateway is wicked! And working alongside Lutron, it pretty much covers everything I need to do in the house.
I can also use IP cameras with H.264 stream now that the firmware has been updated. This is very good news πŸ‘πŸ»
I have added areas, zones and some NL equipment for now. I can't wait until it's all wired up.
Progress...
I see some nudges on the roof tiles outside the bifold doors. This will need sorting out.
BLGW working fine.
NL/ML Converter working very well.
The Beolink2 app needs to be updated.
The BeoMusic app can recognise all the sources and do more.
Hay Kiran
My experience is the opposite.
The BeoLink2 app will only show the products if you had added them in the BLGW and assigned them to a zone.
I find the navigation of music much better with BeoLink2
Seanie_230 wrote:
Hay Kiran
I have assigned the TV and Converter in the same zone - living room in the blgw.
I am currently playing the CD from the 9000 on through the TV speakers and all working fine.
When I return back to the Beolink2 app, it asks to select a source and doesn't recognise I'm playing music. Also, the sources of the converter doesn't show up too or the BS9000 icon.
It works in the BeoMusic app.
I can address one thing for the ML devices
ML devices do not provide feedback to the BLGW due to a limitation of ML.
For example when my BV7 is switched on to AV1 and I open the app the app it does not recognise it's on, I have to select the source before I can control or put it to standby.
All the NL devices do provide feedback
I love how you can set different icons on the converter that you want displayed on the apps for the legacy systems.
This is really making me buy a converter for all legacy lol.
Looks wicked though πŸ’―πŸ”₯
Hi Kiran,
If I'm understanding, you're missing the BS9000 sources in the BeoLink App2, am I right?
If that is the case, please check on the BeoLink Gateway setup page that the BLC (the one that represents the BS9000) is defined under Resources and also that their sources are listed in the Interfaces tab.
BTW: Really nice project!
Best.-
fedenunez wrote:
Hi Kiran,
Best.-
Hi Fedenunez
I have mapped the sources correctly and they show up properly in the BeoMusic app.
In the BLGW, I have put my new Avant and BLC under the same zone but the Beolink2 app does not see any sources from the BLC.
If I put the BLC under a separate zone, then the Beolink2 app can see the sources.
I really think this has to do with the Beolink2 app.
Thanks β˜ΊοΈπŸ‘πŸ»
Did you try with the BeoLink App 1?
Can you share your BLGW configuration?
