Hi MM,
You are obviously the on-site resident expert on all things B&O and I thank you for your advice and comments.
When I originally purchased my system it was from a B&O shop in Oxford, it’s no longer there. The guys from the shop struggled to get the system to work properly and had to seek advice from B&O head office. It took a couple of weeks to resolve and they had to install an additional Cisco systems router as well as the existing Sky router. The wiring at the back of my unit on which it sits is unbelievable. I have never seen so many wires. It’s horrible.
Anyway, they got it going. But it was annoying.
In order to download music to the hard drive I had to install an app. That worked for a couple of years until B&O no longer supported the app, one of the guys from the shop worked out a complicated way of downloading music for me which worked on my iMac. I no longer have my iMac so am stuck with no way of downloading music. I have a cd ripper on the system so could buy a cd but I am never going to buy cd’s again as that’s old fashioned technology.
Basically I am stuck with the music I have on the hard drive. I can and do use Spotify via other mediums but that is not an app on my B&O tv. It has Deezer which I do not use.
Trying to use the remote to navigate and use my system is unbelievably difficult. Nothing is straightforward. Typically, the stand for the tv was programmed by the engineers so that it turns to the required position on startup. But somehow one day those settings were lost and I have to turn the tv to its required position each time I turn the tv on as I just give up trying to programme it. It’s the same for just about any adjustment I want to make.
My system is very nice to look at, the music sounds nice on the speakers. The tv is good but of course television has moved on and that’s why I want a new tv.
i would never recommend a B&O system to anyone. It wasn’t a cheap system but I have been continually disappointed with it.
Regarding bass response, I would agree with you but have had a demo of the latest Sony Bravia Oled 65” and that does have a built in sub woofer which does enhance the bass much better than other Oled tv,s I have seen lately.
My engineer is the local B&O expert as he was used by the B&O shop when they were here, so he knows the B&O systems.
Hopefully I have addressed the points you make.
regards
Dennis
