MX5500 S-VHS input settings
Hello,
I´m trying so setup a connection between the TV-out from my HTPC and the S-VHS input from the MX5500.
I have found out that there is a whole setup menu for the MX 4000 - 6000 - 7000, but when I press menu on the remote I can only adust
timer and p-link.
Any ideas how to setup the S-VHS input on the MX5500
thanks,
Henk.
Don't you have those connectors 1 and 2 in the menu (see image in attachment)?
Configure the scart to be "v-tape", select "v-tape" and then press shift + 9 to activate the s-video input (use the scart for sound).
Yes it's working!!
Thanks guys for your quick answers.
