MX4000 turning on/off when radio turned on/off; a link issue?
I'm hoping someone will know the answer to this problem. My newly purchasaed but old MX4000 MKII turns on and off when i use my BEO4 to turn the radio on and off too. I suspect this has something to do with V-option or Link-option but I can't tell and i have no idea how it was used before.
can anyone suggest how to change this option? The BEO4 manual didn't really have many suggestions. I have ot fix it as it's really going to confuse my 70 year old mum :-)
 One good thing is that the sound to the TV goes off when i turn on the radio and i like this feature but have no idea how tochange this
thanks
pb
Are MX and audio in the same room? Then press: STDBY + LIST  - arrow up...  - V.OPTION - 1. The same procedure with A.OPTION.
Hope this helps.
Stefan
many many thanks stefan, that did the trick 🤒
is there anywhere e.g. on beoworld or bang-olufsen.com that explains how the different Video and Audio and LInk options via Beo4 work? I remember a page on the old Beoworld but couldn't find it here. i'd like to be bale to keep the muting of the TV when the radio is turned on
You think of this? http://www.beoworld.org/beotech/
Stefan
yep that's the place! many thanks
