MX-7000 worth repairing?
As far as I know the problem you discribed can be caused by two problems. One is a defective picturetube, in that case it is not worth repairing. But this is almost never the case. I think there is a problem with the G2 trimmer, this is located on the PCB that is on the picturetube. And that's an easy fix.
Thanks, maybe worth to have an B&O technician have a look at it and take it from there. I don´t have any skills to do anything myself.
Armed with the information above any decent TV repairer should be able to carry out the work🙂
