Mx 7000 problem
Hi i have got a strange problem with my TV. when i push the button menu, colour ,contrast and brilliance change a lot in strengt.
when i exit that menu colour ,contrast and brilliance will go back to what it was before.
When i go back to Menu and into Picture and try to change colour ,contrast and brilliance it happens big changes
in that menu but when i exit again i dont notis that big change.
The Tv will not store the values i change.
hope you understand
best regards Christian
Are you storing it correctly?
Picture, Store, Store.
Hi there is no store on a beo4 remote but i push picture and then go just like it says in the user guide
Once you have set your values, press "go" on the Beo4 not exit.
Incidentally, you can add "Store" to your Beo4 but only after adding "V-SETUP"
Andy T.
i have added v-setup and it will now store the values temporary but if i turn off the tv and turn it on again it will not go back
to the last stored values, it put itself on 50 in brightness 46 in colour and 50 in contrast
Does this apply to normal tv channels or only whilst viewing external source ?
I experienced similar with watching external set-top-box (when pressing MENU, the picture changed)
This was caused by the settings of the set-top-box, it was set to RGB, which the MX7000 doesn't support.
Hi you where right ignace the problem only appered with external sources
so i change my ext sources to other output than rgb and then the problem dissapered.
thanx a lot
