Hello,
we're moving back from London go Germany and need to set the sound system back from "I" to ""B/G" ...
Does someone know how to do this on a rather aged MX 6000 ???
Appreciate any hints!!!
MOR
Hello,
MOR
Think it should be in the Menu - tuning area - if a multi standard tuner is fitted then an option with I should scroll thro the other tuner options if only I is available the the tv was country specific!
I recently moved an MX7000 to france and it had a multi standard tuner fitted which worked fine until June 8th when my area went digital - now use a cheapo Elap ultimo 2 box which has the advantage of a usb outlet to record to hdd - cost about 30€!
salut
Tony
Bad news i'm afraid, there is no was to do this with the MX range of TVs. In europe I think the MX range are either continental european (PAL B/G) or UK (PAL I) and it is a different tuner board between them. I think the NICAM encoding is also different between the UK and the rest of europe.
I agree - with earlier tv's country specific however later tv's like mine has a multi tuner which covers all western european counties - you may be lucky!
Tony
