Does it mean replacement of the back up battery?
No problems with program presets.
/Erik
Thank you, sgresswell...
Do you have the specifications of the back up battery?
Is it easy to find?
/Erik
At least in my Beovision MX3000 the battery is 2,4v NiCd, with soldering tags on both ends. My electronics dealer had one in list and I order but received an NiMH-type. When I asked they told me that EU will deny making cadmium-batteries and so the type in catalogue was replaced. Also I was told that in these type of application the NiMH type can be used to replace the NiCd.
The battery looks like this (the actual one is a bit longer): http://www.wd-is.de/wdis/wenbilder/23004.jpg
