Mutiple ML distribution boxes.... Quick if possible...
 I'm in the middle of the install now.......so a quick answer please.....sorry for the rush...
If i've got say 6 passives....can I run 1 ML distribution box for the downstairs....and then run 1 of the connections to a ML distribution box upstairs......??????
Yes that is possible
So for instance:
Radio ------ TV (master) (between radio and TV split cable in the middle)
ML Juction downstairs ------ one cable from junctionbox downstairs to junctionbox upstairs
Shouldn't be a problem and infinitely preferable to what your multiple ML junctions would otherwise look like. Wish more people used those five-way distribution boxes more!
 Nick
Awsome...thanks for the help....and quick......
Just to be clear...the ML distribution box has the Audio IN and then 4 link slots...so...
 I'd use 1 of those 4 to run upstairs to the AUDIO IN of the ML distribution box upstairs....
then.....i'd have 4 links available upstairs...yes??
thanks again guys...K
Sorry Frank, i was confused. Look at this link
Hi Chucky....on my ML distribution box.... 1 says Audio Link..., 2 says Video link..., then it says ML link 1 thru 4.......
 How does that all work??? thanks, k...
Ok this is my setup
BS 3000 in audiolink
BV7 in videolink
This is important because I think this should be paralel
Then you can use the rest for link audio. If you want to setup another TV You need to run a coax as well from your master TV.
The labels on the ports on the ML distribution box, apparently, are for aid only, and don't meal a thing regarding the kind of connection you're going to link to... I say apparently, because (maybe it was my setup), but the LINK 1, etc ports really acted like Links when I wanted to merely extend a ML cable's length in an ML experiment in my living room. Hopefully your results will vary.
-Sal
😁Sal you are right, but i thought that the audio and master should be connected together and the ML cable should be split in the middle
So Audio    ----------------- Beovision
                       I
                       I
 Rest of ML distribution
This should help
