Hi guys,
I have wired most of my speakers in to the router and this has appeared to solve the problem for now. However, I have a few speakers I cannot hardwire in such as the Beoplay M3. I can live with that, but upstairs I have an A6 and BS 1, which still do not sync and drop out. I can't hardwire either of them, because of the distance between them and the router. Would you suggest power lining them or using a wifi extender upstairs then using an ethernet to the extender plug?
@CB I found when using an old Bose system that giving the speakers a static IP address solved many issues so maybe give that a try. I have all my current B&O speakers on a static IP with as much bandwidth as possible. Hopefully with the speakers now wired instead of wireless it will solve the problems I have been having.
Thanks for all the support guys. It is much appreciated.
David
