MPAV9000 - advice needed
The Masterpanel AV9000 only works in combination with the AV9000 with Software 1.2.
Sofware above 1.2 doesn't work.
Really!!!!
The Software 1.1 at the Masterpanel lost timer function.
The timer at yaer 2000 did not work.
Software 1.2 for the Masterpanel is possible.
Ulf
It works! Itworksitworksitworks. :-)
Well done - how have you got it connected and does it work fully?
-sounds very interesting... do you have full control of the MCP9000 though the Avant? (CD, radio, tape)
/m
I do have full control, but as mentioned above, it doesn't seem possible to get the MPAV menus (eg tuning) to appear on the Avant. Which is a pity. It is simply connected via the Masterlink cable, with the Avant set to Option 2, and the MPAV (supposedly) set to option 0.
