Moving House Eclipse 65 Location
I don’t like either option but out of the 2 the second is the better choice.
Much depends on where the sockets are located unless you have free reign to change all of these around.
Without looking at this in too much detail my initial thought is to change the position of the right hand sofa with the tv and BL5s as shown in Option 1. This is a nicer setup with a good sense of space around all the objects in the room including fireplace, radiators, doors, tv, sofas etc. However, since the tv and speakers would now be in the middle right of the room, you’d need to consider how to cable it all in. The easiest way would be with a large rug that goes up to the walls and then hide the cables under that. Not necessarily the best solution but the easiest workable without too much extra work.
Addiional questions:
1. What is that behind the tv/speakers in Option 1 - a large window?
2a. Where are the tv, electricity, telephone points etc?
2b. What will you need/use for tv, satellite, cable, other?
How about trying to create two ambients. One on the right side with your BV and BL5s opposite to where they are in your first picture and a second zone/ambient with the fireplace, maybe more reading/chilling/chatting oriented.
Good morning
I have a question if anyone can help and its about power consumption.
Is it ok to have the Eclipse TV part and sound center with apple TV on an extension lead 13amp fused on one of the sockets in double socket and the other socket running a Beolab 5 or in fact both of them.
Is it OK to run eclipse and 2x Lab5 speakers on a double 13amp socket?
I know some people use an extension lead off a single but I would prefer to be safe from the beggining. currently My whole setup runs on two double 13amp sockets with a single 13amp power lead to the TV that splits into three C7 cables using a splitter.
Thank you
Sean
Hello there
I tend to agree with you that the room flows better with the TV on the right side away from the fire but I can still see the fire from the main sofa.
as for the additional questions
1. Its a large window
2a. The sat cable and single power socket is next to the radiator, I hope not too close as I found at Screwfix a 1 gang to 2 gang or a 1gang to 3 gang power socket convertor fused at 13amp which I could use for 2x Lab 5 and Eclipse.
2b. I only use Apple TV additional to the two power sockets for the TV which I have combined as one.
cheers
Sean
