How do you recommend to move this TV, is it possible to lift it - and where should we grip it.
SAKRUN
SAKRUN
The easiest way is to simply remove it from the stand before moving it. Moving everything in one go is IMO to risky and hard.
Seems to be much work just for moving TV 30 cm?
Definitely remove the TV from its stand first, and then move it in two pieces. Trying to lift the BV-7 with stand will risk bending the aluminum face plate on the motorized base. It's flimsy and easily bent - not like the first generation BS-9000 floor stands that were solid, polished aluminum.
Tip it backwards very carefully, slip a bedsheet folded as thick as possible underneath. Tip it forward and slide sheet fully under. Then slide into position and reverse process.
Jonnie
Jonnie
Wow JC, good tip, did not think of that one at all...Wonder if it also works with BV4-103 :-)
Thanks!!
Very big shett and 4 people!!!!!!!!😕
Jonnie
