Hello Everyone,
I have a motorized stand under my MX7000. Does anyone know whether it would fit under the last from the series, the MX8000 as well?
Thanks for any reply!
Hello Everyone,
Physically will fit but the motors are different electrically.
The 7000 DIN plug has 4 pins and the 8000 DIN plug has 5 pins.
Thanks for your quick reply Graham.
Is there any adapter or would the motorized stand simply be useless for the 8000?
Am I right in thinking it should be an easy rewire?
It is only the motors that are different, the stand itself is identical.
The motors are quite different but I can't remember why. It is not a simple re-wire. That has been proposed before and discounted.
I live in Cologne, Germany - but we still got a flat in London as well ... but if it's not an easy plug-n-play I probably would not go through the trouble of "upgrading" from the 7000 to the 8000
I have an 8000 type motor which I would willingly swap for a 4 pin type. Is it worth it for you?
There's always a solution 🙂
...one of the things I LOVE about Beoworld! 🤒
