Somfy are too loud. So are mechoshades. Lutron makes the only silent drive on the market in the US. I don't know of any made elsewhere either.
In terms of lighting and shading, it's not like a new company is going to pop up out of nowhere with a viable solution. Lutron, as I see it, continues to be the best out there. They're going to market with several distinct tiers and most people can find some level of control within their budget. Even if it's just a few local IR dimmers or an occupancy sensor in the bathroom.
As I see it, you're better off just picking up a few RA2 components and building the system over time. You'll be much happier in the long run as it's going to be like purchasing an appliance. If you use the stove every day it won't matter 5 years from now that you saved $250 on it. All you'll think about is how slow it is to bring water to a boil.
