Motor Stand from BV10-40 on a BV11-40
Hallo
Does anyone know If the motorstand from abv10-40 will fit and work on abv11-40?
Regards
You can mess around with (and replace) the rear fittings and eventually it'll hang on there - but the motor part of it won't work as it's totally different on the BV11 (fitment).
Lee
Thanks for the quick answer 🙁
