More strange Penta behaviour.. I replaced a few caps in the amp board and it seemed fine again for all of that evening. Next morning I switched on and it was no longer working - I suspect a transistor may have failed so I'm ordering a new board (not ready for ICE just yet...)
Does anyone know how the input mode switch is supposed to work? On the other Penta I notice that the left-right position actually makes no difference to the signal being amplified. First noticed this when I adjusted the balance control on the BC9500 - both speakers are louder in the centre setting, and both fade slightly on full left or right. So I de-soldered the left channel wire in the DIN plug for the right Penta and now the balance works (I have a B&W passive temporarily standing in for the broken Penta), however it makes no difference whether the input on the Penta switch is set to L or R. I would expect that if the L wire is not present there would only be a signal coming through the speaker amp when the switch is set to R...???
I wonder if there is a problem with the input control board which is mixing the L & R signals - and perhaps this is what has caused the left Penta amp to fail? It doesn't seem likely to me, but perhaps someone here can comment?
Steve
