There is already a mechanism to link to other sources, it would be a simple update to expand that UI/UX paradigm to push music to other sources.
let's put on the table another scenario:
I am in bedroom, turning on A6. Moving then to the living room and through the link turning on moment and joining A6. So far so good.
Then I just want to turn off Moment, but by pressing the pause on the moment turns off also the A6!!! How can they by ungrouped without using the app??
have a great week full of sound :D
I think I understandIf you turn off the moment using pause it will pause music on link roomUnder the tablet there is a button to switch off only the moment when connected to the link systemslet's put on the table another scenario: I am in bedroom, turning on A6. Moving then to the living room and through the link turning on moment and joining A6. So far so good. Then I just want to turn off Moment, but by pressing the pause on the moment turns off also the A6!!! How can they by ungrouped without using the app?? have a great week full of sound :D
under the tablet where??
thank you
That is a mute button, right?
To the left on the sound hub when you have lifted the tablet.
yes, but this is the mute button, does it turn off the beolabs??
Since you are using the source of the A6, this will have to turn it off (too).
Wonder what the answer of the Moment team would be - can you have a 'tap to un-join'? How could that be realized?
Only workaround, I can imagine, is to change the output of the Moment to another source (one of it's own sources) and then turn it off.
This probably won't have any influence on the A6, and this should continue playing, I suppose.
What happens if you use a remote?
Short touch (of the standby button) should turn off the adressed device - long touch all devices on the network.
Quick brainstorming: the link tab on the moment could be always on, and just like the beomusic app to be able to remote control the a6, change the volume, group, ungroup, off / on, change source etc.. that would be true multiroom. Cause now we are kind of tied to our iphone / ipads etc.. it is only software issue
