Success!!
Thanks for your help, a fully-wired powerlink did the trick - without an eye.
Now, how do I adjust the volume balance between the existing active speakers, and the new passive ones?
Adrian
Success!!
Adrian
You can't
That's a pity, but I did expect it.
Success!!
Adrian
You can only do this with Masterlink and the Remote Eye. You have just discovered the difference between the two wiring conventions.
Perhaps a future modification is in order. Thanks for the info.
Adrian
