MLGW Telegram
I think we need to use "Scheduler"
I tried many times but fail to give a time in Macro.
I have my Conson house control system connected to the MLGW via the RS 232 interface.
From the B&O app I can both, control multimedia devices and the Conson lighting also. So far so good.
Now I would not use the B&O app, but CommandFusion (is much confidential). This means, I want to send a signal from the house control system via the RS 232 interface for MLGW. And this is exactly my question, how should look this so called telegram?
I have no Conson house control, but my MLGW controls a Lintronic relay board via RS232.
You have to set up your MLGW for RS232 use. Set baudrate, stop bits... of your Conson in the MLGW, and find out which RS232 commands the system uses. You can jaust put it in by numbers.
Maybe this helps (?):
http://www.commandfusion.com/wiki2/hardware/cflink/on-board-rs232-port-protocol
Stefan
Hi
sorry to disturb your interessant discussion, I just bought a secondhand MLGW and I don t know how to find the configuration tool ?
THanks in advance for your help
Hi Stefan
Thank's for your help. Unfortunately the protocol from CommandFusion doesn't help. They use an other telegram syntax. My search for a solution is going on.
Hermann
Hi Stefan
Thanks for this precious information !!
Best regards
OLivier
