ml powerbox alternative
I can try to test it if I can find the time later this weekend
That is very kind! Regards, Johan
Interesting. Roughly what I expected to be in there. The 5-pin chip is an unregulated charge pump used for inverting the + 5V from USB to -5V. The smaller ones on the other side of the board are indeed some diodes and two resistors. They are used for providing power to the data lines.
Ok so if I understand correctly the ML power box only deliver the 0.25/-0.25V for the datalines and not the higher voltages on the pink and blue wires?
What could be the reason for not having the supply of the data voltages in the BLC NL/ML? Is it because there can only be one unit providing it in a ML network?
Ok so if I understand correctly the ML power box only deliver the 0.25/-0.25V for the datalines and not the higher voltages on the pink and blue wires?Yes, it provides the termination voltages for the datalines and 5V to the ML Power + pin. Probably ML Power - is also supplied with -5V but I don't think any of the common ML devices uses that. As I said earlier everything will communicate just fine if you provide it with the data termination voltage and 5V on the pink + blue/white cable.
What could be the reason for not having the supply of the data voltages in the BLC NL/ML?I have never looked into a BLC and there is no public schematic available. I don't know if it is using the old ML ASIC or a discrete solution. In any case I put my bets on a hardware design issue. They either may have just forget about that feature during development or initially it was never planned for the BLC to become a master. Who knows...
Is it because there can only be one unit providing it in a ML network?Technically you could get away with multiple Power Master" if they have at least some reverse current protection. Maybe two or three would still work okay but the cleanest way is of course only having one.
Ok so if I understand correctly the ML power box only deliver the 0.25/-0.25V for the datalines and not the higher voltages on the pink and blue wires?Yes, it provides the termination voltages for the datalines and 5V to the ML Power + pin. Probably ML Power – is also supplied with -5V but I don’t think any of the common ML devices uses that. As I said earlier everything will communicate just fine if you provide it with the data termination voltage and 5V on the pink + blue/white cable.What could be the reason for not having the supply of the data voltages in the BLC NL/ML?I have never looked into a BLC and there is no public schematic available. I don’t know if it is using the old ML ASIC or a discrete solution. In any case I put my bets on a hardware design issue. They either may have just forget about that feature during development or initially it was never planned for the BLC to become a master. Who knows…
Thanks Madskp - ML Power box still part of the factory planning :-). Regards, J.
One thing that just came to me if you have the Beolink passive in mind. If it makes sense could you use the BLC with an IR eye as the linkroom and the the passive connected via powerlink to drive passive speakers?
The powerlink cable has to be fully wire for this to work
Hello Madskp, that is a good hint, did not think of that option yet. And to be complete, even the fully wired PowerLink cable might not be enough to get it working :-) https://forum.beoworld.org/forums/topic/beoplay-connection-hub-beolink-passive/
My latest plan is to use a BLC (I do have a 'JOIN' IR eye already) and two BL7-4s (that I now have as well). I will see to feed the L/R speakers with Left and Right signals only. I took the BL2000 to the garage for a 'fit' and I fear it will be a bit small in the 3x6m space. And now I have a purpose for those 7-4s!
The BL2000 will move to the garden I reckon (cabled).
Thanks, Johan
Thanks, Johan
And to be complete, even the fully wired PowerLink cable might not be enough to get it working ? https://forum.beoworld.org/forums/topic/beoplay-connection-hub-beolink-passive/Yes that's right. This might also be an issue with the BLC
My latest plan is to use a BLC (I do have a ‘JOIN’ IR eye already) and two BL7-4s (that I now have as well). I will see to feed the L/R speakers with Left and Right signals only. I took the BL2000 to the garage for a ‘fit’ and I fear it will be a bit small in the 3x6m space. And now I have a purpose for those 7-4s!Talking about an upgrade :-) But this will avoid those extra boxes for sure (unless you count the 7-4s as boxes).
