Would you think a 5V USB to RJ45 cable could do the trick too?
A long time wish of mine is to get some sound im my garage. I already bought a BeoLab2000 for that reason. I like the idea that I can control source and volume without a remote or app. The only problem is that I cannot elegantly bring an ML cable to my garage. So my plan B is to use an Airport Express (as a wireless client), connected to a BLC, connected to the BL2000. Until I realized I need to power the ML network with an A. Master. I do have a spare 1611 that could do that, but I like the idea to use the BLC's USB for that (and to keep the chain of boxes limited to two).
Login to view image
(OK I admit, that is a third box. And they are rare and/or expensive to various level of craziness!)
Reading the text, I was hoping that I could fabricate a cable that just brings the 5V USB of one socket to the correct RJ45 pins of the RJ45 ML socket of the BLC. Or am I seeing this way too simple? Has anyone done this?
I am doubting myself, as the ML handbook says:
- supply voltage: -7 V to -15V, in standby -3V to -15V
+ supply voltage: +7 V to +15 V, in standby +3V to +15V
Hope someone else has been wondering about this also :-)
Peter Pan is missed...
Regards, Johan
