membership renewal: problems
im facing some problems with the renewal of my gold founder membership; for the time being i just lost that status and i can't renew it.
i guess i need some help
thanks in advance.
I've just renewed, took a minute or so, and I got the gold status (and the coveted "f") back.
One thing - do the drop down that changes the type from bronze to gold - it defaults to bronze when yo fill the form in, which could be your problem ??
Regards
David
Hi
Yes the reason you are now bronze is that you didn't renew within the renewal period and your membership will default back to bronze. All you need to do is go to this page  http://www.beoworld.org/register.asp?action=regrade_view and upgrade your account to gold. Your previous membership status will then be reinstated.
Regards
Van
Van,
Thank you for your prompt reply.
Now everything is just fine.
Strangely my status is not gold founder :( :( :( :(
sorry lee
it seems that was a cache problem; now i do see it.
thanks 2 u all
No problem Pedro, glad we could help you out.
Regards
Van
And thank you for renewing Pedro - it really is appreciated by everyone at BeoWorld.
Lee
