Hi
Does anybody know the difference between Software Version 2.1 and 2.3 of the MCL2AV Type 2031 (XTRA TV Kit)?
David
Hi
David
David,
The following issues were fixed by version 2.2:-
Wrong volume level and wrong display read-out in x-tra active speaker room.
If an audio source is activated from an x-tra TV room, the volume will rise to 34. If BM 5500 has already been switched on, the volume should be raised to 10. If BM 5500 is in standby mode the volume should rise to 20.
Subsequently, the following issues was fixed with version 2.3:-
Dear Keith
Thanks a lot for this information.
Best Regards, David
